Background:
2006 LJR Automatic
Seldom used in last couple years.
Battery is a 2019 Optima.
Needed to move it off the driveway last week, after a few hours charging I only got some "click, click, click" when turning the key. Pushed it off the driveway. Yesterday, put it on a 10a "smart" charger for 4-5 hours, and the charger eventually displayed the "bad battery" light. It wasn't taking the charge but did for the first couple hours. Tried again today and this time connected the charger directly to the battery posts, not the battery cable clamps. The light for "fully charged" came on after 5 hours or so. Got in the Jeep and turned the key with absolutely no results. No dash or curtesy lights, no clicking, no nothing. Got out the multi meter and touched the contacts to the battery terminals, got 12.28v. Touched the contacts to the battery cable clamps and got the same 12.28v. The mice have been in the engine bay (and I assume over the transmission, in the frame rails, etc.), but I've never found mouse droppings inside the Jeep. So, I highly doubt any wires inside have been chewed. In the engine bay, there is a couple examples of some insulation having been chewed, but nothing major. I traced the cables from the battery.
- Wire to fuse/relay box near air filter is fine.
- Wire to starter is fine.
- Wire to alternator is fine.
- Wires to ground on block and firewall are fine.
What would be the first fuses and relays to check?
Do I need to remove those grounds and clean them?
Is there a tutorial here explaining what is involved in the system between turning the key and the battery energizing the starter?
Thanks in advance for your help.
2006 LJR Automatic
