Hello! I'm about to do a coolant flush/swap and/or system clean this weekend. I've heard that mixing coolant colors is not a good idea but I'm not sure what was originally in there. This is a 98 TJ Sahara 4.0
Does this matter that much if I drain (don't plan to pull the engine block plugs) and refill with the wrong one?
And based on the photos, does a system clean seem like a good idea? My process is drain, flush, and fill with distilled + Prestone (should I add additional coolant?), drain, flush, and fill with Thermocure (do I need coolant here?), drain, flush, and fill with Zerex
