‘02 TJ 4.0.
I looked in my reservoir recently and was appalled at all the gunk. I think when I had the block plugs replaced recently they put in the wrong coolant.
I’m following this thread https://wranglertjforum.com/threads/how-to-flush-the-cooling-system-on-your-jeep-wrangler-tj.1737/
Although I’m not doing the tee in the heater core line, I don’t see the point of it.
So far I’ve drained the radiator, flushed it with distilled, could not get it looking clear so I added a bottle of Prestone coolant cleaner and will be driving the vehicle around for a couple hours to let that do its thing before I drain that, drain the block, and then refill with zerex G05.
Question is pretty basic: what do I do about the reservoir? I understand topping off the radiator, but should I add a 50/50 mix into the expansion tank directly until it reaches the fill line as well? Or do I leave it empty? And any suggestions on cleaning it? There’s an impressive amount of gunk on the walls, but not like I can get a brush in there or anything.
Thanks, appreciate any tips!
