Revolution gear part number
gatertamer
Mud dauber
Lifetime Supporting Member
Pacific Northwest
Why can’t I find the correct part number on their website for 4340 chrome moly front axle shafts for 2000 tj with dana 30 …27 spline with an e locker?
Simplify your search. TJ Dana 30
Every time I click on a tj it says 2003-2006…..aren’t they all the same?
For the USA shafts with the 1350 U joints (out of stock)
https://www.revolutiongear.com/product/97_06_tj_lj_xj_and_zj_us_made_front_axle_kit_27_spline
or the discovery series
https://www.revolutiongear.com/prod...ep_tj_xj_yj_wj_27_spline_kit_discovery_series
It does show 2003-2006 but they are all the same for the dana 30
Are the discovery series inferior….yet still better than stock?
are the discovery series inferior to the ones made in us…..but still better than stock?
I don't know that inferior is the word I'd use. The difference is that the USA (Foote) version uses a 1350 U joint and has a lifetime warranty whereas the Discovery series uses a 5-760X U joint and has a 10 year warranty. Both are 4340. And yes, Discovery is way better than stock.
Reactions: gatertamer
Just received my Dana 30 Discovery series shafts and the came with the standard retainers (half circle) and a set of full circle snap rings , which should I use?
These say they're for the Dana 30 without a locker but I don't see any reason why they wouldn't fit a locker
