Jackery portable battery bank or inverter?
Jackery Brand is WAY over priced. For what you get.
Geared toward Millennials who can't figure anything out.
But Hey they have as cool website the crap they sell must be good said one Hipster to another on Twitter.
They want $700 for a 200watt solar panel.
On Amazon for $400
https://www.amazon.com/dp/B0B9SP6BNH/?tag=wranglerorg-20
Get a AGM battery from Walmart more capacity less, cost plus back up to jump your jeep.
EverStart Platinum AGM Battery, Group Size H8
https://www.walmart.com/ip/EverStar...Size-H8-12-Volt-900-CCA/40647529?athbdg=L1103https://www.amazon.com/dp/B004W5SGBO/?tag=wranglerorg-20
And a inverter
https://www.amazon.com/dp/B08SR1KNL4/?tag=wranglerorg-20
The left over money will fill your tank for an adventure.
If you want your jeep to charge it get one of these.
https://www.amazon.com/dp/B08RSD1M5L/?tag=wranglerorg-20
Not that it matters but Im not using a jackery branded solar panel. Went with a 3rd party from amazon and all works good. Your solution is good but a totally different setup vs a small portbale / solar rechargeable unit. I even take this on my motorcycle camping trips.
I have a Jackary 500, and a 120w (non-jackary) panel, only really use it to run a camp fridge and small device charges. When I use it, I always have the fridge plugged into the DC out, and either the solar panel or the vehicle on the DC in (when driving). My fridge will keep food frozen for 3+ days in the Florida heat, and I can keep my battery fans/lanterns as well as phones and speakers all charged. We have also used the setup during power outages, hurricane emergencies, baseball tournaments, etc.
I did install switched 12v outlets in both the Jeeps to charge the Jackary.
Nobody uses AGM as "house" batteries anymore. The prices of LiFePO4 batteries have come way down, the size and weight per amp hour is substantially less than FLA or AGM, and one can use all of the battery capacity rather than just 50%.
Reactions: MikekiM
There are many brands that to it as well or better than Jackery for less money. Go for one with newer LifePO4 batteries, safer then lithium ion and better charge/discharge characteristics.
Check out this youtube channel for reviews of all sizes of power stations:
https://www.youtube.com/@Jasonoid
I've been trolling that website trying to get up to speed.
