I noticed my brake lights were not working the other morning. Checked the fuse and it had blown. I put another fuse in and it immediately blew when I tapped the brakes.
I have read several threads on this and tried to troubleshoot the issue with out any luck.
I do have LED brake lights that the previous owner installed and they have been working up until this point. I have done my best to track down a short or bare wire between the brake lights and switch. Everything seems to be wrapped up and protected well.
The blinkers work which seem to be on the same wire as the brake lights which makes me think there is not a short between the switch and brake lights if the blinkers are working.
I tested the switch and it seems to be working. Does anyone have a diagram on the switch there seems to be several wires coming into the switch. One of which is a pink/blue that has been spliced several times by the PO. Those connections look okay.
Any ideas would be greatly appreciated. I may just buy a new switch to see if that fixes it.
Thanks in advance!
Thanks in advance!
