Folks, this is my first thread since I recently joined the Forum.
The blue high beam dash light stays on even when the lights are on low. I replaced the headlights with new ones because one of the led headlamps went bad. Too expensive to replace so I purchased standard halogen lamps. in replacing them, the headlamp on the left (facing the jeep), there was no continuity to ground. I installed a new ground to the headlamp and the lights due change from low to high but the blue light on the dash still stays on. About a year ago I had the replace the multi-function switch but the lights worked still worked fine. I also traded out the HB relay with another but that didn't eliminated the blue light problem.
Does anyone have any ideas what to do?
TJ
TJ
