Hope your body mount bolts give up more easily than mine...Not enough wine and dinner first, I guess.
NorCal jeep it's whole life brah. Those body bolts will zip right out. Now I just jinxed myself.
You finally gave in!
Only half way. Just a small butt crack.
Oh my goodness. I can’t believe what I’m seeing in that box. Soon you’ll be tempting the plumber.
I think these would look great on your white TJ...didn't like the look of the cubes where I had them located, so I moved them.
View attachment 31261 View attachment 31262
Gonna order some round fogs.
https://www.amazon.com/gp/product/B00MA8728S/?tag=wranglerorg-20
Hey are you still using these back up lights? just wondering if they held up and how bright they are?
If they do, I couldn't find them currently produced. Ours was a 2005, and it was special ordered by the OP. They are rare.
do you still have them on your bumper? just wondering if they really brighten things up a lot
Thanks !! i went down to O'Reilly,s and they had the bulb. Just installed them and they worked great. Cant wait till tonight so I can see the difference .What really helped was replacing the back up bulbs in the stock tail lights to LED bulbs.
Go in the garage and close the door and look at them now!Thanks !! i went down to O'Reilly,s and they had the bulb. Just installed them and they worked great. Cant wait till tonight so I can see the difference .
No doorsGo in the garage and close the door and look at them now!
Well shoot!!No doors
thanks !! I do what i can. hopefully about to add sye. drive shaft . and disconnects .Well shoot!!
That is a fine looking Jeep!!
I really like doing the little things that upgrade the stock equipment that are inexpensive like the bulbs, ive done tie rod, and extended brake lines like that from other Jeeps types. Ive picked up stuff from salvage yards too. its been a blast.thanks !! I do what i can. hopefully about to add sye. drive shaft . and disconnects .
Good for you! That's what its all about!I really like doing the little things that upgrade the stock equipment that are inexpensive like the bulbs, ive done tie rod, and extended brake lines like that from other Jeeps types. Ive picked up stuff from salvage yards too. its been a blast.
