"Pacing myself" build
Only half way. Just a small butt crack.
GOm17haXZHtzJIUj5Rw1q-Nium_yOZWpcTS7e11h3SGNU04dx2LfdInjPqq7E0c6Y7v_ODeRHumOz9VN1SI=w600-h471...webp
Spent a couple hours at the shop doing stuff. Adjusted the front pinion angle a bit. Got is at 0.6* to the drive shaft angle. Caster is at 6.8*
Added a bit more bumpstop to the rear to keep that pesky TB bracket in check.
I don't count the bolt head cause the jounce bumper will absorb it.
Moved the fuel pump wiring harness out of harms way. You can see where the TB bracket was hitting the tub.
Installed my CB mic holder to the dash.
Reactions: Chris and JMT
thanks !! I do what i can. hopefully about to add sye. drive shaft . and disconnects .
I really like doing the little things that upgrade the stock equipment that are inexpensive like the bulbs, ive done tie rod, and extended brake lines like that from other Jeeps types. Ive picked up stuff from salvage yards too. its been a blast.
Good for you! That's what its all about!
Reactions: StG58
