I'm having automatic transmission issues in a 2006 TJ. Seems to be a 1-2 problem. If I'm sitting at a complete stop, sometimes it won't go when i give it gas. I have to let off the gas and then gradually give it gas for it to go. Other times I drop it into neutral and back to drive for it to catch and take off. I just picked it up from the shop and they are recommending a reman or rebuild. I just had a rebuild four years ago and two years ago I had a transmission cooler installed because it was running hot. Here are the codes the shop pulled. Looking at these codes, does a rebuild or new transmission look to be the only option?
PO700 TRANS CONTROL FAULT
PO714 TRANS TEMPSENSOR
P1776 LOW REV SOL.STUCK
P1790 A-SHIFT FAULT VALVE BODY TEMP SENSOR FAULT
Thanks!
Thanks!
