RangerRick
"A Jeep Rescue" Home for the abused & neglected.
West Coast
Back in May I ran across a TJ Wrangler on Craigslist for all of $300. Since I have a soft spot for cheap, neglected & abused Jeeps that seem to "follow" me back home like a rescue home for the marginalized Jeep, it ended up in my collection of ongoing restorations and rebuilds. It needed work. A lot of work! So here will be the first of possibly many articles on the restoration and upgrades I've done or plan to do on my $300 TJ special "Red Headed Stepchild" appropriately named because it's RED.........
As part of the restoration of my $300 TJ Wrangler Craigslist buy, I was replacing the interior with the newer interior from a 2005 Rubicon model I purchased, swapped and traded parts for. After doing some paint and bed liner spray-in treatment to the floor pans and interior with Kevlar embedded polyurethane liner, it was finally time to install the 05 Rubicon interior. As one of the bonus upgrades, I happened across a 2002 dark agate or "slate" full console to upgrade the half console my $300 TJ came with originally. This had the subwoofer and amplifier inside the console but the subwoofer surround was completely rotted away and the dust screen was rattling loose against the speaker cone.
After reading many different posts on the various forums all over the web, I choose to follow a slightly different path and use the newly released Stillwater Designs "Kicker" brand 43CWRT672 mini sub. This sub fits the bill perfectly since it is almost an exact fit size and dimensions plus it uses the "DVC" Dual Voice Coils technology if you wish to re-use the factory amplifier. After talking with the good people from Crutchfield where I bought the Kicker subwoofer, we both agreed the factory amplifier would not be up to the task of powering a premium quality speaker rated at 300W (150W per voice coil) as the factory amplifier only makes about 40W x 2 per output from a very small device. Bottom line, I would not be happy... Here are some pictures.
Remove the console by lifting out the front rubber cup holder and rear cup holder liner. Remove the bolts that hold the console to the tub floor. You may have to remove the shift boot or automatic shifter and loosen the front half of the console to lift out the back half. Unplug the amplifier connector located under the front cup holders. Depending on year, this will be a 6 or 12 pin connector usually grey in color and remove the console. The connector changes; 2001-2002 early connector, 2003-2006 later 12 pin.
Turn the console upside down and remove these speed clips that hold the brackets to the bottom of the cup holders (pointing to with a screwdriver).
There are 3 screws around the speaker grill that must be removed and two more inside the lid of the console. Removing these 5 screws and the two speed clips will allow you to separate the subwoofer & amplifier module from the console so they can be worked on.
What you will notice about this subwoofer when you have the enclosure removed from the console is the wires run in a channel from under the edge of the speaker on the front of the box. There is a rubber glue that is used to secure the original speaker and seal the enclosure so that it is air tight. This is important that there are no air leaks when you re-install the new speaker because it may cause sound effects in your music at certain frequencies. The Kicker is designed to be used in a small sealed box so we want to make sure the foam that pinches the wiring is in good shape and the foam on the back side of the new speaker makes a good air tight seal.
The new speaker has a larger magnet and basket structure so you will need to "dremel" out some of the ribbing in the inside of the enclosure. Sorry I forgot to take a picture of trimming the ribs inside the box for the new sub to fit. You will need to trim a little bit more on the bottom side of the enclosure as the subwoofer sits at a very slight angle in the box and is tilted downward. Trim a little then test fit is how I did it and it only took about 15 minutes with a cutoff wheel and careful depth measurement with a ruler.
If you are choosing to re-use your factory amplifier built into the back passenger side of the enclosure, please understand it will not be able to drive the Kicker 43CWRT672 to it's full potential performance. The Kicker sub has the same 2 Ohm rating per voice coil as the factory sub, however to fully drive it will require a different amplifier. The factory amplifier as I mentioned earlier is only rated for about 40 watts per channel output. I chose to use a Kicker 42PXA300.4 300 Watt 4 channel amplifier to power the sub. This amplifier is designed for motorsports and off-road or boating and is very very small. I will post pictures of this amplifier soon. Don't let the size of this tiny powerhouse fool you, it puts out! The amplifier will produce 75 Watts per channel, almost 2 times the total factory Jeep amplifier at 2 Ohms on 2 channels and I will have 2 more outputs for some 6x9" 3-way speakers in wakeboard tower cans on my back roll bar. Lots of tunes for a very small footprint amp that will be hidden high up in the dash to avoid water and mud. Id rather not test it's "waterproof & mud-proof" rating when crossing Fordyce creek next summer!
The picture of the factory amplifier heat sink. I gutted the amplifier and left the heatsink to seal a large hole that would otherwise be in the back of the enclosure since this is supposed to be a SEALED ENCLOSURE BOX. The picture of the gold screws is to sealing up the two screw holes that were where the heatsink mounted to the spacer that conducted the heat from the amplifier circuit semiconductor. One of the pictures shows the small amplifier circuit encapsulated in glue and plastic that powered the factory subwoofer (black plastic horse shoe looking thing on top of a newspaper add).
Please note: your rear speaker wiring is connected through this amplifier so if you want to bypass it without affecting your sound bar speakers or pods, you can tape or heat shrink the connectors that went to the original sub speaker. Leave all your wiring in tact and just add four more speaker wires from your new sub spring terminals to your aftermarket amplifier. Make sure the original terminals cannot short or touch anything or short out as they will still have power to them. Carefully route your newly added wires through the same area using care to make sure the gasket behind the speaker edge will still seal well. Add silicone if you believe it won't seal well.
Screw down your speaker directly into the plastic housing making sure it fully seats all the way around the back side of the frame. The speaker will sit slightly offset LOW in the opening because there is a relief in the top of the housing that will force the speaker not to sit perfectly centered because of the CD holder in the arm rest compartment. This is OK and will not affect performance of the subwoofer if you make sure the ribs were trimmed and the speaker can fit flush with it's opening relief. It is a tight fit and I angled the speaker in carefully to watch the wiring terminals and routing. Take your time to get it right, it will fit snug and require all 8 screws to secure the speaker in place. I used 1" drywall screws as this is the automotive industry standard for subwoofer boxes and the heads fit perfectly in the speaker basket. Start by screwing in the bottom screws then work opposite to the top and sides careful the basket remains flush and sits flat and your wiring doesn't get disturbed coming out from under the left side of the speaker. ( Seems wordy but when you mount yours, it will make perfect sense and you'll SEE what I'm referring to.
It is IMPORTANT that you DO NOT OVER TIGHTEN THE SCREWS as they are only going into plastic and can strip out easily. I repeat, careful not to over tighten the speaker mounting screws. There are 8 of them and they will hold the speaker in just fine by themselves.
A few more pictures including the final product: Notice the Kicker logo peaking from behind the grill of the console.
On a final note, when re-assembling the console, assemble in reverse order. If you were careful when removing the speed nuts that secure the outer console to the subwoofer module brackets, you should be able to re-use them, they will keep the brackets and console lined up when re-installing the console in your Jeep. Re attach the subwoofer 6 or 12 pin plug to the OEM amplifier unless you have removed the original amplifier as I have and re-wired your rear sound bar or pods to bypass the factory amplifier. Install all removed screws and don't forget to replace the rear cup liner when you've finished the job. Nobody should realize you've just added high performance audio parts since they are not visible and fit where factory equipment was mounted to help avoid theft of your new sound system. Don't forget to switch in the low-pass crossover for your subwoofer and adjust the bass gain to balance out your system if you've installed an aftermarket amplifier to drive your new Kicker subwoofer. I will have more on installing and adjusting aftermarket amplifiers in another edition of "How To:"! Thanks for reading and feel free to contact me if anyone would like help on this or any other topics I post about in the future.
RangerRick
Thanks for the very thoughtful how to! This is definitely going into the how to section in the next few days. I know there's a lot of people (myself included) that would like to upgrade the crappy stock subwoofer!
Thanks Chris! I will try to make better posts as I "learn" how to craft them on the forum. I have more updates and pictures and details about the swap and will add more soon.
Rick, GREAT post! So, It has been a year and I'm curious as to how everything still sounds. Getting ready to replace my 01's blown sub and use an aftermarket amp as well. Thanks!
Everything still works awesome!
I have upgraded the rear sound pods to 2005 pods out of a Rubicon that I swapped the entire interior except the actual dash and half door panels. I am going to upgrade the dash speakers to 5 1/4" JL audio units with some $9.99 adapter rings off ebay. The Kicker sub really puts out a lot more volume and power than the original paper cone unit especially with that Kicker amplifier in the dash. I was going to install some boat wake board tower cans on the roll bar in back with waterproof speakers because i have 2 more channels of amplifier available to use if I want. Perfect for tunes at camp. Im happy and nothing stands out saying "break in and steal me" so it's all good! Thanks for asking!
Now I am thinking of moding my center stack bezel to accept a double DIN touch screen android powered mobile GPS AV receiver with nav, Bluetooth, video camera inputs and multi codec decode playback that can control my android Galaxy phone & iPod classic. I upgraded my iPod from a 5th gen 80 Gb to a flash drive .5 TB SSD memory array. Between satellite Sirius XM, Pandora and 500Gb of iPod tunes and videos, I have want not for what not on a soundtrack to fit any driving experience in my Jeep! Gotta love mobile tech!
The only thing though about replacing the quality head unit, albeit 13 years old, is my Pioneer head unit sounds way better than any of the China made android AV receivers ever will. The Pioneer has high end audiophile grade DSP equalizer and mosfet amplifiers. It is one of the only receivers that has a working signal strength meter for AM, FM, satellite & cellular phone signal. It also has the burr-brown high end D to A decoder chips in it just like 4th & 5th gen iPods have the sonically better D to A converters over 6th & 7th gen units. In geek speak, they are better, not that anyone would notice in an open top Jeep! But I digress, my days of mobile audio competition from decades ago creep in every now and then when messing around with car AV.
Wow, so glad I found this @RangerRick, I'm going to follow what you did to a T.
With the Kicker 42PXA300.4 amp, is there a lot of extra wiring involved there to replace my stock amp?
There is a bit of wiring involved but it will be worth it especially once you're cruising down the freeway and can actually hear your audio speakers over the road noise.
I know how to solder really well and make my own wiring harnesses, but I'm horrible at reading wiring schematics and diagrams. How did you figure out how to wire yours amp up?
Reactions: RangerRick
The factory service manual had the schematic of the sound system and how everything was wired up. It was easy to locate the wires to the amplifier and disconnect them when you rewire using an install kit that comes with the correct factory plug pigtails. Never cut your harness if you can help it. Then I ran new wiring to the amplifier and subwoofer that was in the factory enclosure. I removed the amplifier module from the heatsink and put it in a box to save if I ever desired to return the system back to stock configuration. It sounds way more difficult than it actually was to do. The hardest part was finding a sound bar connector in the salvage yard so I could connect the factory pods I used (from a 2003-2006) TJ/LJ Wrangler without cutting the factory wiring in my Jeep. I wanted it to look factory yet sound sonically superior to where thieves would pass my open top Wrangler by without any notice. The factory wiring is there, just not plugged in, instead my harness I made with the stereo install kit, junkyard or ebay wire pigtails and aftermarket speakers hiding in plain sight behind factory grilles in the factory locations. Nobody knows any different. There are 5 1/4 adapters in the dash for bigger than stock speakers I bought on ebay for $10 shipped made out of metal, be forewarned about the plastic ones, they crack and vibrate. JL audio dash Xr series, same with the sound pods, JL all matching. I added some R16 fiberglass insulation batting as dampening material in the overhead pods. Then I added some in the subwoofer enclosure during the modification process for the console sub replacing it with the Kicker DVC driver. The amplifier is hidden way up under the dashboard behind the radio and climate control HVAC panel near the instrument panel. Previous swamping of another TJ in Fordyce creek has taught me there is an air pocket under there so it would take driving your Jeep into a lake to get water clear up there and the radio will be long drowned before that happens. I can still hose out the Jeep without fear of ruining anything because the speakers are all poly cone and the sub is mud/off-road/marine rated. The amplifier is also off-road mud sports rated according to Stillwater designs. 75% of my listening is from the several hundred Gb worth of solid state memory I converted my 5.5 Gen iPod to. Then theres about 20% listening to Sirius XM satellite radio and about 5% videos, GPS nav or cellphone calls.
RR
RR
I wouldn't ever cut my factory wiring harness for anything, no way! So to avoid doing this, do I need to find a junk yard and source out factory connections / pigtails from the stock wiring harness so I can splice them into the wiring that comes with the new amp?
HA!!! It's funny that I found this thread this morning...I ordered a Kicker CompRT 6.75" DVC 2 ohm sub and a Kicker PX 200.1 mono amp and they arrived yesterday. I spent a couple of hours doing this exact thing last night!! I never would've thought that you'd get a decent sound from such a small sub! It isn't ground pounding but it is exactly what I needed to balance everything out in the TJ!!!
A 6.75" fits perfectly in the factory sub enclosure and the amp fits perfectly underneath the passenger seat, where the jack would normally mount. Both the sub and amp are weatherproof and are designed for ATVs, motorcycles, etc so no danger in the rain damaging them (I am usually topless/doorless (even in cold weather)!
The sub is a dual voice coil so I used a Kicker wiring diagram to wire both coils to the mono amp (I have attached it for reference.
The amp was $49.95 (Amazon) and the sub was $79.95 (Amazon). I also purchased a BOSS Audio 8 gauge amp install kit and it was $18. A local stereo shop wanted, (are you sitting down?), $935 plus tax to what I did in two hours!!!
View attachment 35553View attachment 35554View attachment 35555View attachment 35556View attachment 35557
How did you run the power wire to the amp? I’m looking for a hole in the firewall on the passenger side, but can’t seem to find one.
There is a rubber grommet on the driver's side firewall...It is directly behind (in line with) the exhaust manifold! You can easily access it underneath the dash and just drill a hole through it (easier than removing/replacing it) and fish your wires through!
If you have a single voice coil sub, the mono 1 channel amp is great. Kicker stuff is meant for off-road mud and desert motorsports. I have friends with the same amp I run in RZRs, single rider 4x4 quads and trick dune buggies..... Glamis style 100 MPH $150k dune toys! Awesome stuff, not meant to be a plug for any one company but the stuff is made for this life.
Reactions: Geojunkie_George
