What is a waste-spark ign?
Emissions stuff. The coil/plug fires once to ignite the charge, then again on the exhaust stroke in an effort to reignite/burn off any remaining fuel/air before it exits the cylinder.
I know at least four people who have purchased and installed the MSD ignition coil with good results, my point is buy it and try it before you knock it. Don't make assumptions about a product from a very reputable American company.
I think the points being made against are primarily around what scientific principle is at play that would cause us to need to try it? It is established that the existing coil is more than powerful enough to jump a large gap. The PCM is in control of when & how long the spark will be, so what possibly could the MSD being doing to improve the performance?
We're not (necessarily) not arguing with your results, we're asking how could it possibly do what you claim given how the OEM unit already works?
Stop trying to claim or infer you have ignition system expertise because you "work in the automotive industry". There are many including janitors, assembly line workers, secretaries, accountants, suspension engineers, tire specialists, etc. who also work in the automotive industry but they sure wouldn't try to claim expertise in ignition system technology.I work in the automotive industry in Detroit,
It will be within a few data points of how long the MSD product lasts and likely more than a lot better. I typically see 200,000 out of the OEM coil rail and even then it is never a diminished performance issue, it is an outright failure.I don't know what the failure rate is however, I would be curious.
It's very hard to get butt dyno data into a printable format.
I have a supercharged 06 tj and I have run the MSD ignition coil rail for two years with E3 spark plugs. I had my engine stroked and and blueprinted, with three Dino pulls before and after there was a six HP gain with noticeable throttle response and reduced emissions. You should not bad mouth the product until you've used it and tested it thoroughly.
So, you had your engine stroked and blueprinted - and you gained six HP on the dyno? You must have been quite dissapointed…
Don't get me started on E3 spark plugs either, they're right up there with throttle body spacers on the TJ and tornado air intakes which are all pure snake oil products lol.There you go again, trying to flex on us with your 10+hp gain.Was that from 8 E3s and a Fram filter?
It's abundantly clear you're not an ignition system engineer or you'd easily have understood by now what we've been trying to tell you why replacing the OEM coil rail with one from MSD won't make a performance improvement in a TJ. You totally ignored the several reasons given why it wouldn't help and never responded to any of those points. That you recently decided to add that you "work in the automotive industry" clearly, in your case, clearly doesn't mean you have any technical knowledge of ignition systems.
Dino Pull #1I had my engine stroked and and blueprinted, with three Dino pulls before and after...
OK.. I can't lie. I have the MSD ignition rail.
Traded a set of Toyota Koito H4 headlight housings, a cheap Amazon shift boot and a cheaper Amazon leather steering wheel wrap, for a new, sealed box MSD Ignition rail plus a bag of Doritos and six pack of Sam Adams... only because it's red. And I like red. The Doritos and Sam Adams were red too.
Truth. I have zero ignition system expertise.
The rail made zero change in performance either way, but it makes my balls swing a little lower when I look at it so.. I'll keep it for a while. I still have the OE rail in the event the MSD unit shits the bed or my balls begin to retract when I open the hood..
Why didn't you mention this.......I have a stroked 4.0 with a super charger....
^^^^^^^^ That there is funny..Is that benefit actually listed on the tin? If not, I feel like they've missed out on a marketing angle...![]()
I have been running an MSD coil for two years now with no problems however, if your setup is pure stock there will not be any noticeable gains and it will look nice. I have a stroked 4.0 with a super charger and there are definite benefits with the MSD compared to the stock rail.
Are you running an intercooler with that setup?
I’d love to see the charts from the dyno runs you mentioned. Post them up if you have them.
