I found the smallest one button garage door opener I could find for our Genie and stuffed it under the roll bar pad
That shit is 100% GARBAGE; besides, it leaves a sticky mess on everything that is fails to adhere to.
Same w/ double-faced tape.
Even the VHB from 3M isn't going to hold up if it is exposed to UV and/or heat.
GeniusI didn't like the idea of my opener being visible and accessible with the top and doors off. Years ago on my last TJ, I wired up a small, discreetly placed push-button switch and mounted the opener on the inside of the switch panel.
I didn't replicate the mod on my current TJ, I use my phone for garage opening now. (sorry Zorba)
I use my phone as well. I don't feel comfortable with a garage door opener just hanging out in my TJ either.
I finally installed factory Cruise Control on mine. Took less than an hour, and works great!
This OMIX replacement bow straps are trash and now I need to replace my replacements so I picked up 20ft of 3in webbing from strapworks for half the price and I’m going to make my own.
Full write up when you're done, please. I have one that flaps in the wind now, and one that's tearing.
Genright Stealth LEDs. They come with an angled aluminum bracket that bolts up with the hood catch. PM me how to wire them in if needed. They don’t blink, marker only.
These are zip tied on, they will mount more outbound when permanent.
I picked up a set of the GenRight LEDs with the fenders that includes that marker light. I went with the Metal Cloak because of their due-use marker/turn signal for the front. I hadn't seen them illuminated so thank you for that pic. They really are stealth un-lit but visible when lit.
I like having something as a turn signal for folks to my side on the highway. I may go with them as a turn signal option to the side of the Jeep with the front already serving as a marker.
My @Plumber1 copycat is going pretty good-
The LED marker lights that Blaine sells would be a good option.
