Tie rod end is really stuck
Might try a tie rod end/pitman arm puller- Harbor Freight sells ‘em
Reactions: CreepinDeth
The pitman arm and tie rod puller did not help remove the tie rod pin. All it did was mushroom the top of the pin.
So first I had to remove the top of the pin with a hack saw. Then I used a 4 pound BFH and a center punch 5 times. That didn't work so I tried plan B and hit the knuckle 5 times. That also did not work so I went back and tried the center punch again and finally the pin dropped. I think it was the combination of the two that finally broke it loose. And, yes, the BFH was key.
Note the angle of the center punch is because I was swinging up past the fender. Had a video to show all this but it wouldn't upload, so the second two images are screen shots.
Glad I didn't have to resort to Thor's Hammer. Couldn't find one on sale.
Thanks to everyone for the help. Much appreciated.
