P
PNW_LJ
Guest
The first time I took it on trail after the paint job, my passenger rear tire rubbed the edge of the armor and took the paint off the edge. The good thing is it's aluminum, so it won't rust, but it is a lot of work to prep and get a good paint job to begin with. The good thing about aluminum is its easier than steel to sand and get flat and scratch free. Once you get it that way you have to wipe it down with a vinegar and distilled water solution, then self-etch prime it, all within about 15-20 minutes so there's no flash corrosion. Once it's self-etched, you can treat it just like painting steel.
That's one thing about painting armor is making sure you leave the edges about 150 or 220 grit so that when you paint it gets a good bite on that edge, because if you don't then the most likely places the paint will chip are along the edge and edge face. The rest of it you sand to 400 grit.
I know you don't really need this Jeff, but it might help the OP.
Thank you for this.
Considering the shitty job I did at spray painting my rear bumper.. not sure I’m ready for a project like this. Body work is not my strength
