Finally decided to open up the NSG370 I purchased for my project. The guy said it would come out of 3rd gear while driving, he mentioned no other issues. I took some pictures of the assembly on the stand and was hoping some of you who have rebuilt the same transmission would be able to tell me what needs replaced.
Shift Rail Guide: I know for sure needs to be replaced as the plastic is broken. Ordered the bronze guide plate from Whitbread Performance.
5TH-6TH Synchro Assembly: Looks fine to be but i could be wrong.
Reverse Synchro Assembly: Looks fine but could be wrong. Maybe the sleeve looks worn? The shift fork pads looked normal and were not broken.
1-2 Synchro Assembly: These do look worn/rounded.
3-4 Synchro Assembly: Look a little rounded so probably replace?
also how do you tell when you need to replace the synchro assembly vs just the synchronizers & friction rings?
