Best stock look headlight upgrade?
I installed these in my TJ 2 years ago and have been very happy with them.
X2 on the KC lights stated here i've run these since buying the tj in 2010 right now i run hella 500 driving lights set to on with high beams really lights the night. lows are 2x better then stock atleast
The kc highlites quad beam is awesome because it keeps the low beam elements on when you go high beam, almost blinding!
I was lucky and bought a pair of the Roundeyes H4 conversion headlamps back in 2008 before they went under. I still have them installed and they still look and work great,
Holly RetroBrights would get my vote for best stock appearing headlight.
If those are too expensive and you want traditional halogens, then the Toyota kits are good too. I found them better than Hella and what I currently run until I switch to the holleys
Holly's look really nice but very expensive. Can you tell me more about the Toyota kits?
Reactions: DasBitz
Reactions: Longwhitejeep
I also have the Toyota bulb and wire harness in mine. HIGHLY recommend it. The Jeep factory harness is garbage and eventually overheats and damages the plug at the multi function switch. Once you switch over to the Toyota harness, the load on the multi function switch goes down and you can have pretty much as high a power bulb as you might want. I did upgrade the bulbs to Hella H4 100/80 watt bulb.
Reactions: C.J. Roberts
