i’m in, leaving bennett, so i will need a location
as i stated, wife’s JK on 31s if that’s allowed.
I believe the recommendation is 35's, at least 1 locker, winch, skid plates, etc. It's a tough trail. I've never seen anyone run it on 31's I've seen one guy here run it on 33's but his tummy tuck TJ has much more ground clearance than a JK. If it's wet it's going to be considerably more difficult.
I don't recommend attempting on 31's. Can someone else chime in on this?
I wouldn't try Chinamans on 31s. 32s with a really really good driver and raised skids, maybe...
https://www.trailsoffroad.com/trails/255-yansing-gulch-aka-chinaman-gulch
it is a rubicon so locked front and rear. i’ll probably just met up with everyone to put some faces to handles and take my son to a different trail then.
ordering the SSSye now so the TJ will be ready next spring.
I definitely would recommend not doing this on 31s. You and your son are definitely welcome to ride with me if you would like.
Lets plan on meeting at and leaving the trailhead at 10:00. I may stop at the Gunsmoke before but I should be at the trailhead by 9:30.
Edit:
Time and location is subject to change based on input of those who are going...
Trying to work my schedule so I could come up for this but would need to be back home at a reasonable hour. How long does this trail typically take to run?
Are you coming from Pagosa?
I would be. Still up in the air if I’ll be able to make it yet. Won’t know until tomorrow.
Has @lBasket sent it yet?
