Issue: I added an OEM soundbar and dome light to my 2002 which originally did not have a sound bar but the dome light doesn't come on when either door is opened.
light turns on via the multi-function switch and also turns on with the kick panel light for approx 5 - 7 seconds when the key is turned off so the bulb is good. Harness has the yellow wire from the lower kick panel to the sound bar. A harness from a 2001 (soft top only) was used to connect the sound bar to the orange kick panel plug.
Fuse #4 is tested and installed
I searched for a hidden switch and don't see any modifications.
Both doors have the switches and the switches appear to be in fine order.
According to the attached schematic (still learning to read schematics) there is a yellow wire associated with the sound bar missing from the LHD 2 speaker soft top harnesses. Is my vehicle missing a wire in the dash side harness that would connect the door switch to the dome light before the orange soundbar plug, since it wasn't there in the first place?
Any ideas on how to proceed with solving this one? Perhaps it's a blessing to not worry about not closing a door, but on the flip side, it's irking to not understand why the light doesn't work.
