My Curt trailer hitch that I had with stock fuel tank will not fit with the genright 24.5 tank that should fit like factory. The skid plate is about 1/2” too wide. Any suggestions or is there another trailer hitch I could purchase that would fit?
I'd imagine your only option will be to get a rear bumper that has a trailer hitch built into it. You bought a larger than stock tank so I'm not sure why you figure it would fit like stock? They had to make it larger somewhere to be able to get the added capacity.
I would run this one from Genright, my buddy had it, its very nice. I have a similar one w/o the hitch.
https://genright.com/products/jeep-tj-lj-rear-bumper-w-receiver-hitch-step-v-2.html
Since you are back east to save on shipping you can go to Motobilt.
https://motobilt.com/collections/je...-cj-yj-tj-rear-rock-crawler-bumper-bare-steel
Bolt-on receiver hitches like that cause that kind of problem, they also reduce ground clearance. You'd be much better off getting a bumper with an integrated receiver hitch like from https://www.thedirtworx.com/product-page/rear-bumper who manufacturers their bumpers right here in the USA. Their prices are even very competitive with cheap Chinese bumpers that don't hold up well.
This is my DirtWorx bumper with an integrated receiver hitch, I've installed two of them over the years.
The way I read the description was if it works with your stock tank it will work with this tank. I assumed it meant in general, but looking back at it, I think its only referencing the axle/rear suspension clearence.
I believe the GR tanks tie into the frame, so that causes the interference, but I don’t have the GR tank, I’ve only looked at them prospectively. I agree with the above, get a bumper with an integrated hitch.
Pictures of where it interferes might help.
WTF kind of "hitch" is that? Is that even an inch spacing between the edge and the hole for the hitch pin.
The inner faces of the bracket interfere with the side wall of the skid plate.
That drawing does not answer my question in any way. What is your point here? I can pictures too!
That is the shortest "hitch" that I have seen.
Mine was for a rock crawler and its breakover angle and ground clearance were both fine. Especially with the receiver hitch not being mounted below the bumper. I'd give them a call, they're a great company. Before his bumpers took off and got so popular so he was able to open a manufacturing facility I went to his house about 40 miles from mine to pick my first one up, he was making them in his garage. They're really an exceptionally well-built and very beefy bumper.That one does look pretty nice. Looks like they’re out of stock, so I don’t know if they’re discontinuing it or if it’s just a back order but will be back in stock. Ill have to give them a call. I guess fortunately or you can also look at it as unfortunately I dont need to worry as much about breakover angle and ground clearance, there’s really no rock crawling going on around my area. We got mall parking blocks but thats about it
The numbers are all over the place. @Blackjack said 2.5" is the standard for a 2" hitch, but the variation is large as you see in the thread below. Even with all this, the Motobilt one seems quite small, no? Hence my question.My Warn has the hitch pin hole about 1 1/8-1 1/4” from the back edge. I’m not sure what is “acceptable,” but I’ve never had a problem using a cargo carrier or pulling a trailer gross loaded weight under 2,000lb.![]()
The numbers are all over the place. @Blackjack said 2.5" is the standard for a 2" hitch, but the variation is large. Even with all this, the Motobilt one seems quite small, no? Hence my question.
[URL]https://wranglertjforum.com/threads/receiver-hitch-pin-distance-survey.65431/[/URL]
