Did you add the license plate light after the first pic? Because I’m not seeing the light.
Is this made in the U.S.A. ?
CA. V.C. says a lot of stuff regarding plate mounting but nothing about the angle.
It finally got dark enough here. The plate light is plenty bright.
I don’t get why one would go through the trouble of getting slimmer tail lights (besides looks) and keep the stock license plate holder. I’ve smashed the stock one twice (which dented the tub corner when it folded over) and never touched the tail lights.
For one,I’ve had a couple people just about run into the back of me,the stock single 1157 bulb is just not that bright.
I haven't seen that here in Florida - but the Popo will pull you over for something like that sooner or later. They pulled me over a couple of months ago because the license lites were both burned out on the old MBZ. I was actually glad they did, as I had no idea, even if it did scare the crap outta me at first. Then the deputy and I got into a friendly discussion about guns - Goddess I love this state!
Knowing Blaine’s attention to detail, the quality of the instructions will probably rival the obviously superb quality of the tail lights
It is in the DOT specs.
All I found in federal DOT rear plate holder requirements is a maximum allowable upward angle from vertical, as long as the upper edge of the plate is under 47.25" from the ground. So anywhere between vertical and their chosen number looks kosher. How do they come up with those numbers
Im not being a troll. I find dumb regulations and V.C.s interesting. Im a "spirit of the rule" guy, and Ive been jammed up enough times by PD, CHP, and DPS that pointing out they are wrong brings me joy.
Your tail lights would last about 2 trips in JV, or less than one depending on the trail.
What is the alternative? I personally think the plate mounted to the tub and hammered to fit the tub curve looks like shit and I’m surprised that’s not an issue with law enforcement either.
Only other solution is move it to the spare which has its own pros and cons.
Stick to the mall, Boogie.
Yours gets my vote for "Jeep most in need of a set of Mr. Blaine's soon to be released billet LED tails"
