Looks like SEM has three options. I don't see any straightforward compare-and-contrast info on their site. Any guidance on when to use which? Any positive or negative experiences with any of them?
I'm thinking about using the XXX since it sounds like it has the widest applications, and I'm not a pro needing the minor improvements provided by a different rattle can for each little job.
I think that @Moab use the Plastic Adhesion Promoter over here.
UPDATES:
ANSWER: See here for SEM's answer, "Step 3".
UPDATES:
- Plastic Adhesion and XXX Adhesion sound almost identical. Spec sheets both say they are "excellent on olefin based plastics". They both "seal substrates and increase adhesion of top coat materials to a wide variety of raw plastics" and are encouraged for "topcoat with most refinish products".
- Sand Free, on the other hand, "softens ABS, PVC and similar plastics to promote adhesion" and "works on ABS, PVC and similar plastics" via a "wet-on-wet application [that] melts color into substrate". Says it is "perfect for interior plastic parts".
- HOWEVER, I ordered some XXX and the front of the can says "Improves adhesion to plastics, aluminum, steel, glass, chrome, and painted surfaces." So apparently it is indeed intended for more general application than the Plastic Adhesion.
