This seems to generally be a confusing issue for folks to wrap their head around. There are some calculators out there that help figure some rough parameters for material selection but they can also be used to compare the different strengths of similar shapes in solid and tubular. This one is easy for me to use so I work with it from time to time to figure out some of the basics.
What you want to do is pick your material and size and then start changing the load number until you get the safety factor to 1.00 or as close to that as you feel like messing with.
I picked 1" solid bar to start. You can read the comments but when you get the safety factor to 1.00, that is the load the bar will hold before failing in a static condition.
So here is where it gets interesting and why some things matter and while on the face a statement may be true, the difference is actually negligible to the point where it may be readily ignored and not be factored into one's decision making process.
If we take the solid bar and reduce the wall thickness to .4375 to create a 1" diameter tube with a 1/8" hole through it, watch the safety factor, it doesn't change.
The reason it doesn't change much or enough to matter is the strength of a tube over solid is reduced by how strong or resistance to being bent as what it would take to bend the rod that was removed or in this case, a 1/8" diameter rod. The rod strength would be better to figure out if the force box allowed loads with a decimal as in 1.5 but it doesn't so the safety factor toggles back and forth between good and not good with 2 and 3 lbs of force applied. That's also why the safety factor didn't change enough above to show up.
Caveats- This is just a rough way to figure out the questions to ask about something. Something like a greasable bolt with a small hole drilled in it for a grease path. Most of the time the question asked is whether or not it is weaker and that answer is always yes with all other things being equal. The better question is whether or not it is weaker by enough to matter and in most circumstances, the answer is no. Or, even better, is it strong enough to do the job and that answer is mostly yes.
Early on in the TJ model run, lots of folks were complaining about why Jeep moved to the much weaker 5 on 4.5" bolt circle to hold on the wheels when the 5 on 5.5" version is so much stronger. The simple answer is the smaller pattern is more than strong enough so it doesn't matter.
A materials engineer can make a case that there is some strength picked up by having an inner and outer wall. I'm not that smart so they will have to explain it. I am aware that gun drilled axle shafts tend to work a fair bit better since they are more rotationally forgiving and tend to twist further and spring back more than a solid shaft will with no permanent damage. There is a whole bunch more to it than that, but it does work and the reason we don't see many GD shafts is we don't need them enough to justify the expense.
Rogue Fab has the calculator on their site.
Check my work and see if I screwed it up some place. I use this to figure out control arm diameters when needed compared to the lengths we need. Helps me pick between solid and tubular in steel versus aluminum. I hope it will be helpful for other discussions.
