Looks like a good way to leave a seat stain good thing jeeps are light
Yeah for sure, I don't think I'd have made it if my buddy hadn't put some weight on the driver side rear corner for me.
Did you have a change of underwear with you? Maybe some wipes? Always keep wipes around.
Here's a video of me nearly discovering the tipping point on my TJ, this was my first time taking it out after I bought it.
https://photos.app.goo.gl/AtHJBedmQtgcvDax7
@PNW_LJ had a recent close call similar to that...looks sketchy as all hell but I feel like someone more experienced than me has a trick up their sleeve to get out of it. My first gut instinct would have been to cut the wheels in the opposite direction of the tire that's in the air but I don't really know if or why that would help unless that would make the right front climb.
Only in static conditions.I surprised this hasn't been posted yet: https://wranglertjforum.com/attachments/finding-cog-guide-pdf.182461/
Forklift and a strap works too of course.
In my situation it all happened very quickly. From a controlled descent to almost flopping took 1 second.
I think the best action if you really think you’re going over is to gas it. When it happened to me, I panicked and stomped on the brakes. That won’t happen next time.
Well unless you're facing uphill...then it might not be the best idea
You’re right. Uphill best course of action is to slam it into reverse. Or hit the clutch if manual.
The tipping point varies depending on too many factors to say it will tip at x degrees. Speed, tire pressure, traction, tire traction, center-of-gravity point, track-width, wheel width, if you're also turning and which direction are you turning, etc. I'd also say 6" of suspension lift is more than is needed for 35" tires and unnecessarily raises your COG (center of gravity) making it more prone to tip than would be with a slightly lower suspension lift height.
This is mine with nothing more than a 4" suspension lift plus a 1" body lift with 35's. That suspension lift and body lift combination also gives a lower COG than you'd have with a 5" suspension lift and no body lift and way less than if it had a 6" suspension lift.
I always ask people when they do that if they can bench press 5,000lbs. They look at me strange and then the light bulb goes off.
But OP, no matter what you do, you won’t be as good looking as Jerry. We’ve tried and failed.
Funny trail name, I used to work for Ma Bell about a hundred years ago right after getting out of the military lol.
I like the guys going down the road with one arm out the window ahold of the mattress on top.
“ I got this”
Yeah. Sure you do.
I wouldn't have taken that line. I'd have started more driver and turned hard passenger before going off the ledge so my tires both dropped at the same time (if possible).
If I was feeling like the back end was coming over I'd have likely throttled out of that one.
Easy to say watching the video as an expert at armchair quarterbacking.
