In the process of rebuilding front end (learning as I go) and when pulling the axle shaft to change u joint I noticed the teeth on the end of the stub shaft.
I don't have abs lines running to the wheel. Does that part have to do with abs? I don't see it on most of the replacement stub shafts when I do a google search. Could I buy new stub shaft without it. If so, recommendations / any part numbers would be helpful. Thanks
