I know AndyG pretty good. And he wouldn't sell such a defective product to anyone !
Defective product; no. Defective buyer; well, just ask the last Rubii that he sold!
Since you will be bypassing the safety systems, be aware of how easily they might be accidentally turned on by you or others.
Here's mine.
Here's mine.
I assume when this is done the dash lights become inoperative?
@AndyG now this I like.
Thank you for the idea. I was wondering if there would be a way to place them in the center console area. I assume when this is done the dash lights become inoperative?
I did the Ken white version and the dash lights have perfect function- I still can’t get over the simplicity- All you’re doing is hijacking the front locker wire and the rear locker wire and then the other side of the switches share the black ground- I’m not criticizing jeep - It would be probably hard to find a good used Rubicon if they had not put some governance on the locker system but when you see how simple you can make it work it makes you realize how complicated the factory did things.
Depends on how you modify it.
My switches bypass the factory ones, but still send the appropriate signal to the cluster.
Dash lights work as intended.
You can put the switches anywhere you want.
I did the Ken White version and the dash lights have perfect function- I still can’t get over the simplicity- All you’re doing is hijacking the front locker wire and the rear locker wire and then the other side of the switches share the black ground- I’m not criticizing jeep - It would be probably hard to find a good used Rubicon if they had not put some governance on the locker system but when you see how simple you can make it work it makes you realize how complicated the factory did things.
I’m chomping at the bit to do it to my other Rubi.
So the lights still work with this method as intended. That’s good.
It obviously bypasses the transfer case position safety, but are the other safeties bypassed (<10 mph to engage and >45 mph disengagement)?
Same here..dash lights work as OEM.
Correct- here is what happens -
You are straight wiring the pumps, pure and simple-
When you hit the rear, the original axle locker switch lights up- That is simply because you’re on his circuit- And his circuit is the only one of the two lockers that illuminate the switch-
At the same time the dash light will come on and it will flash until the locker engages
Disengagement works the same way at the dash- You’re not really changing the mechanics of the lockers or the pumps you’re just changing how the power gets delivered-
If you turn on only the front locker you’re not going to see the switch light up- But who cares all that matters is what you see at the dash-
You can engage in 2WD , 4 wheel drive , front or rear - anytime except thursdays at 3:30. That’s Jerrys time slot.
So to disengage just turn off the appropriate new switch or use the original switch?
.... reinforcing what he says, in the the new Ford F250 s they moved the locker switch to the left of the steering wheel- away from passengers.
None of my Ford trucks have had the locker switches to the left of the steering wheel. It’s still on the right side on the 2024’s.
Well he is a pure bred Alabamiam .... he may not know his left from his right
