Someone told me global warming is going to kill us all. Meanwhile, I'm freezing my ass off this week.
you need heated seats FO YO ASS !
![Disappointed face :disappointed: 😞](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61e.png)
I'm thinking something a little more capable of off road, like this !
Are you a midget/Tom Cruise? Seat risers are on my list along side neoprene seat covers and swamp ass.![]()
03 and newer seats are mounted lower than 02 and older were but I have never heard of any seat height differences changes between 2003 and 2006.Edit: '02 and older.
'03 seat position differs from '06. Ask around.
Has any one actually seen or experienced damaged rear Rubicon Lsd gears first …
So my to do list when warmer Temps arrive!!
Replace thermostat
Relocate locker pumps
Locker mod.
I love the idea of lockers in 2hi and 4hi.
Replace thermostat
Locker mod.
Added locker mod to mine also. I was already considering it now it’s a for sure.
Do it. The flexibility to bypass the factory process is really an advantage. You will be glad - don’t be intimidated- its a ground, 2 wires, 2 switches.
I’m not even going to risk driving mine now. It is so over.
Then I'll give you $10 for it but you have to deliver it to Maryland.
Does failing to use the locker in four-wheel-drive risk damage to the limited slip differential-
YES! I didn't make it a practice to lock the rear diff while offroad. After I drove the Hole-in-the-Rock road near Escalante, UT, my rear diff was permanently locked ("crash locking"). There doesn't appear to be any way to replace those gears once they're toast. I chose an ARB to replace which has had a whole other learning curve. It was an expensive mistake.
so is what I've gathered from all this is the limited slip on the Rubicon is not only useless but also causes troubles. so is there a way to remove the limited slip so it doesn't break and cause more damage?
