Distributor on a 97 is making noise. I pulled it out, it has a ton of side to side play in the shaft, which seems to indicate a worn bushing inside the shaft. Who knew these didn't ride on a bearing? Anyway, I'm wondering if anyone has gone down the path of rebuilding their distributor, and where they sourced the bushings. The internet has only a few discussions on this, and nobody has shared a part # and all the threads are like 10 years old off places like a-bodies only.
Somebody here shared the name of a guy in Halifax PA who does distributors, but he said he doesn't bother with the Hall effect distributors, he's mainly into getting the curves & such right on the older units. He also said he would go with a Cardone unit for this, because there's not much they can screw up once you get the end play & side to side play correct. I was HOPING he would give me a source for the bushing, but no such luck. He did mention that the OEM dizzy might be a Prestolite, and I've found bushings for Prestolites but no idea which one I need....and even then the specs are literally "Approximately 1/2" ID X 5/8" OD X 1" long." I feel like "approximately" isn't good enough for this sort of application. But what do I know.
I'm probably alone in this journey, but would appreciate any insight anyone might have.
