My air stopped blowing a few weeks ago and I’ve been slowly descending into madness trying to fix it.
About a year ago I had an issue with it only blowing at certain speeds. I replaced the blower motor resistor and it fixed the issue.
I started having the same issue and then the air went out completely. I read that it could be a bad blower motor that is cussing the resistors to fail.
Things I’ve tried/checked:
New blower motor resistor
New blower motor
Fuses/relay are good
Right side hvac panel connector was melted. Cut and applied .187 female spade connectors.
New hvac panel so new fan speed switch and new connectors on right hand size by vacuum lines (tab was burnt).
None of this has improved the issue even temporarily.
Any ideas on what I’m missing? I absolutely hate working on electrical issues.
New blower motor
