I don’t think my Mopar fan clutch is operating correctly, but I wanted to ask in case I’m wrong.
Here’s a video of it, imo, not properly disengaged after sitting all night (current temp is 43*).
https://vimeo.com/915562573?share=copy
I bought the part three years ago to replace PO’s failed electric fan. This part may be why my gas mileage has dropped…it seemed too extreme to only be a winter fuel issue (if that’s even a thing in Tucson)
I may get this clutch if your are still having good luck with it @freedom_in_4low
This seems like normal operation to me....
And based on my experience with my Jeep, Ranger, Frontiers, and Tacoma (which all had fan clutches), they all make a roar at startup and then quiet down after just a bit of driving. That is because the fluid is thick when it's cold and it takes a bit to disperse and disengage the clutch to idle levels (which is how it should stay until the radiator warm temp causes lockup again)
Are you experiencing any sort of temperature problems, or any sort of unusual fan roaring at times when it didn't in the past?
