04TJJIM
Just so you all know I'm not a robot or anything. I joined the forum to see if any of you all on here may have had the same issue as me. Thanks for allowing me to join!
I have a 04 sahara that everything... I mean everything is new in the clutch assembly, flywheel, shift fork, release bearing, pilot bearing.New complete master slave sealed kit
and still can't shift into any gear with the engine running. Don't use Just Ask
They are useless.
I made a tool with the old clutch slave steel plate and used a forcing screw from my Snap-on T puller. My fork needs to move 1" to release but the master slave will only move 3/4". No one knows what's wrong with it not even me. I've done several of these and this one is eatting my lunch. This is the 3rd clutch, master sealed unit I've put on it. I've vacuum bled it just in case but nothing.
