Tail Light Wiring?
TJ's-TJ
MA, USA
Here is what I think:
Drivers side:
Violet/Black = Back-up (assume this gets 12V when in reverse)
Black/Yellow =Tail light (gets 12V when the lights are on)
Green/Red = Brake/Turn (gets 12V when the brake is on, pulsed 12V when turn signal is on?)
seems to be supported by this pic:
The wiring diagrams are less than clear because they call the black/yellow tail/stop
Can anyone confirm/explain?
So one bulb for reverse and one bulb with dual filaments; one for tail, and one for stop/turn?
sorry for the necro thread, but i am trying to replace my taillights with LEDs and when i took the driver's side light off my jeep and cut the harness free, i found my wires are not the same color as in this thread. i have a solid white wire, a white wire with a black stripe and a green wire with a black stripe. any ideas? advice? i am not an electrical guy, so don't get too technical. this was supposed to be a fast and easy swap, dammit.
Do you have a test light? If so, turn your lights on and turn that side turn signal on. The wire with constant voltage will be the tail light. The one turning on and off will be your turn signal. The third will be your reverse.
Reactions: CreepinDeth
This…..
I wouldnt be wiring anything without the proper tools
($10 for a cheap voltmeter or light)
Invest in at least one of them if youre gonna guess at wiring
I just did this with the same wires as you mentioned and this is what I found: Original White wire is Tail/Running/License/Side Marker, Original Green w/black stripe is Stop/Turn/Brake, and Original White w/black stripe is backup/reverse. Hope this helps someone.
