I could use that to lift me up into my Jeep too.
I replaced my 2006 oem pump assembly before it failed, but it has 160k on it.
I kept it for a spare, but should I rebuild/replace any parts on it or just leave it on the shelf till I decide to trash it?
Was oem Mopar or Bosch?
I replaced it with a Bosch assembly.
Bosch made the MOPAR ones.
They also made the OEM one in my YJ. It went 275K or so before it was not able to keep up with WOT flow.
Ah. So they're branded Mopar built by Bosch?
That triples the price.
I just bought a spare Bosch one from RA to keep on the shelf.
Right. Sounds like Delphi is your big winner.
I didn't think they were still available.
Or is it just the older ones?
Maybe put the floor access panel in and try the Delphi. If it craps out, easy swap.
The GenRight kit costs more than a fuel pump. I guess I could buy the $40 Ebay pump then.
You don’t need GR. Just cut the hole, reinforce the cut edges with angle iron, and bolt an aluminum plate to the angle iron. Walla!
