I have had the same experience as Tworley with the lube lockers. If you are planning on being in the rocks, stick with the RTV. If not the lube locker works great.
I have never had leaks around the differential covers when changing the diff fluid on my 2005 LJ.
I feel like I do it by the book, razor blade & wire brush off the old RTV, then bead new RTV around the pan n leave for 24 hours before refilling.
Actual squish-out:
Well under 90%.
I also used the recommended two-step process. Finger tightened the bolts until the RTV squeezed out a little, evenly all around, and let it vulcanize for an hour. Then torqued the bolts, squeezing out more of course, and waited 24 hours before adding lube.
That is a lot of silicone. More than 90% of the silicone will be squished out or packed in the bolt holes.
I'm going to need you to show me the math on that.
Thirded. They're reusable (within reason) and it makes future fluid changes much faster since you cut out the entire razor blade / wire wheel portion.
I am actually in the market for a front Dana 60 and a RJ60 would meet the need if you have one sitting around.
The lubelockers are great--not trying to discredit them at all. I ran one for years and it held up really well even after removing/installing multiple times. I still have and use one for the rear cover. But if the diff cover is hit often and hard enough, the gasket can break/bend. The RTV at least has the ability to deform and bounce back during a hard hit. How much force to change that...I honestly have no idea. There are several of us who have had lubelockers on the front though and have gone back to RTV due to leaks.
Definitely get a lube locker gasket. It appears to be leaking from the bolt hole and not the gasket area. I’d try pulling that bolt and wrap some Teflon tape on it, and then stick it back in there. See what happens. Or back that bolt off a little, apply some RTV around the hole/bolt, then tighten the bolt back up.
Hello all,
thank you for all the replies.
I ordered a lube locker gasket based on everyone's responses.
While I was waiting for it to arrive I took out that bottom bolt & picked out some old RTV from inside the hole.
like @[B]SouthernTJ2000[/B] mentioned.
I dabbed a little RTV or Teflon tape on the bolt (can't remember which)
months later still no leaks!
Next time I remove the diff. cover I'll be installing the Lubelocker but for now I'm still running RTV.
-In between all this I had to work on my transmission. I went with a lube locker gasket when reinstalling & love it. This brand seems to work great & no more razor blade scraping! definitely recommend for the 42RLE because of how "glued up" the pan can be & avoid bending it next time I drop it.
