Frame rot
Almost done prepping. Will be adding some material here and there to reinforce some thing spots and avoid blowing it out.
I would not recommend doing this job without a lift.
One recommendation for when you are ready to start welding. Undo ALL body mounts and then lift up the body about 2-4 inches on the side you are working on.
This will help the welder when doing the inside. they will be able to get a better angle.
I did this similar job in two stages. The driver side the first year then 2 years later did the passenger side. Both sides are holding up very well and be prepared for the skid plates to not line p when it is all done.
That's a good point on the body mounts its pretty tight in there. Ill see what i can do to get those out.
I was thinking I might be able to without with this flexible MIG extension (Attached)
As far as the skid plate i was going to get it close and kind of verify the alignment prior to welding and make the adjustments then
  • Wow
Reactions: FarFire70
This project is coming along. As expected there have been a bunch of additional patches needed. Needless to say the jeep is a loss and I regret that I will be getting it back together this weekend and likely just selling it. Its got a decent drive train so at least its worth something to someone.
Thanks for the advice appreciate the input.
That was painful to read through from the beginning. I daily my TJ.. it's lived in the NE all its' life. Two owners prior and the original owner was a Jeep Master Mechanic. The frame was/is solid. Drilled drain holes the day I got home, flushed the frame for months in preparation for Fluid Film and POR15. It's holding up well. I repeat the FF annually. Last year I saw a small bit of cancer at the rear and did a spot repair and repeated the FF. Doing all I can do to keep it alive.
So getting it back together this weekend and selling it? You're finished with the welding? All that only to sell it? 😢
Reactions: TheBoogieman
This would have save a whole lot of time and energy....
Just sayin...
That person needs to up their game...clearly at least one more strap is needed, at least one can of spray foam and some chassis black spray paint. Maybe a couple of giant cable ties or some tie wire/bailing wire.
You should have seen the 99 my dad’s friend donated us. The gas tank skid plate rotted off so he chicken wired the tank to the frame LOL
I actually I assisted on a roadside repair using a couple straps to hold the front of a rear leaf spring on a CJ7 from pulling to the side AND about half a dozen giant cable ties to keep the whole mess in line with where is was supposed to be.
Yes it was on the roadside and not a pathside but driving anything back to the mainland (partially by way of ferry) to get an actual repair probably saved near $1000 for any wrecker or flatbed to get it there
