well im having that dreded problem, my skim mod failed need to have my pcm programmed to delete skim key, also i have an aftermarket starter in my tj not sure if that would make my problem more dificult
@adamman1205 I can help you with the skim same day runaround.
Nope, NOT Wranglerfix.com! When I purchased my Wranglerfix,com years ago. I asked him to delete the SKIM key and make some other changes to the programming - NO REPLY - ECM arrived WITHOUT any of the changes I specificity asked for!
Now my SKIM is going bad. I am trying to use my HP Tuners to get into the programming and delete the SKIM function. I finally got the file in the ECM to download into my laptop, but I can't get the changed file to upload from the laptop into the ECM
Ok definitely need it done, how much are you charging, I can get it sent out today?
Buddy, I’m gonna say this plainly because Mark is a trusted and reputable member here and this is your first post since 2020...
I usually don’t say a lot on these kinds of things, but this is actually funny.
It is 100 dollars and same day turnaround.
Word, I can get it in the mail tomorrow, I'm not sure how to pm on here but if you can send me all the info via pm that would be fantastic
Click the envelope at the top right.![]()
Iirc @Chris has PMs disabled for new and low post count members to avoid spam.
Well, I got my ECM back from Wrangler Fix. Mark was nice enough to delete the SKIM function again (Thank you, Mark!). This time I removed the SKIM module BEFORE plugging in the ECM. It starts and runs and keeps running. But after 10 seconds, the security key light comes on and stays on. Is there a way to stop the key light from coming on? Re-installing the SKIM is not an option because I broke it when I took it out. Plus that was my original objective was to delete the SKIM. I believe I have read from other sources that the only way to turn off the key light is to remove the bulb. Just wanted to check before I take out the gauge cluster to remove the light.
Thanks, Shimaze
And thanks again, Mark, for deleting the SKIM for me
Thanks, Shimaze
