Where is a legitimate and trusted source for new or remanufactured fuel injectors?
TheBluesBrothers
Florida
Hello all, My first post here,
I got my TJ in late October with 140,000 miles, (Black Sahara 98% Stock and in great shape) I have been doing all the normal things that you do for a new-to-you vehicle, (oil change, spark plugs, air filter, replace oil pressure sensor, clean throttle body, clean and detail, etc. etc.)
My Fuel injectors are the originals. They have many cracks in the casemate of the injector and I have the P301 misfire now and then. I swapped it to #2 and then got the P302. I have done injector cleaner in the fuel tank and I took the injectors out and cleaned the tips off.
I think at least the #1 is not up to par and I want to replace with the OEM Siemens/Deka but I am having a hard time sourcing from a legitimate outfit injectors. The jeep dealer near me did not even want to entertain trying to track them down and gave me a GO AWAY quote of $342.87 for EACH injector and noted that they are Remans.
The existing forum posts about fuel injectors, (Have great information and a great community by the way!) I have come across have dead links or the link goes to an out of stock webstore.
With that said, Does anyone know of reputable sources?
Thanks!
Precision Fuel Injector...
I also installed a set of 4 hole injectors from K suspension and my Jeep started running very rich with numerous CELs. Ended up throwing in new MOPAR injectors back in and it's been fine ever since.
Everyone talking about the 4 or 12 hole ones being more expensive but the OEM ones for my 06 are like $70-$100 per piece on rock auto/ Amazon!!
Are crown/bosch or ksuspension all good alternatives? Looks like k suspension is the only one that’s way cheaper for a back of 6…
