Hello All,
I frequent this site regularly for information. I'd like to say thanks to those of you who take the time to help with advice, tech support, and personal experiences.
I have had my 2000 4.0L Wrangler for a couple of years now, but I occasionally have an engine stall. 99% of the time it will start right back up without hesitation, its progressed from once every month or two to about once every week or so.
When testing I noticed my fuel pressure would drop quickly after shutting off the engine, 48psi while running to less than 35psi after roughly 30 seconds (check valve in the fuel pump). I changed the fuel pump 2 weeks ago, so now I have 50-55psi while running with no drastic drop in pressure after turning the engine off (+42psi after close to an hour).
Also, I have changed my spark plugs with Autolite XP-985 and installed a new MSD coil rail.
So I am in the process of checking and replacing the usual components in the ignition system. What I have noticed is after this issue occurs, there is no CEL or codes thrown to see in my OBD tool. I even stopped by Advance a few minutes after it happened to use one of their OBD tools, just to make sure it wasn't my OBD reader. I would expect something happening that will shut the engine off, would toss out some code? But I am not an expert in the language of OBD, so I thought I should ask those who may know more about the subject.
Thanks for any information you may suggest.
Chicken
Chicken
