I am working on returning my TJ to mostly stock ride height - maybe a 2" lift at the most, preferably stock springs with maybe a 3/4" spacer. This is my daily, and the forest service roads here in no way require the current 4" rock jock I have - I will not be rock crawling in my future and it is too difficult for my back and hips to get into it as it currently sits.
When installing the currie front track bar I recall having to drill out the frame side mount for it to be compatible with the greasable bolt. I would prefer to see if there is a way to return to a stock, or like stock, track bar - but I dont know if there exists any sleeve that can essentially turn that bored out hole back to a smaller and tapered size.
Another option is to retain the currie track bar and do a rebuild on it (probably easiest option) however I am not sure if it can compress enough to work with a stock height, or 3/4" over stock height without causing interference issues with other components. I seem to recall being informed of issues with this track bar at any lift height under 2" but I'm not sure if that is accurate.
It would be great to have input on this as lifts are something I have to farm out - not having a garage or a hard surface conducive to jack stands, and I really don't want to pay a $200/hr shop fee for them to fiddle with it for 2 days before coming up with an answer, so going into it pre-planned if possible would be fantastic. A complicating factor is the only shop within reasonable distance to me seems to have had major turnover and only 2 guys even know what a Johnny Joint is... So they are not a reliable source currently for accurate information.
Any thoughts?
Any thoughts?
