So far I’ve replaced the MAP, fuel pump, injectors, TPS, IAC, verified no cracks in the intake. Tightened up the exhaust bolts to fix a minor leak and put a new flow master 40 series muffler on with no converter. Replaced the upstream O2 sensor. It’s still running lean. Still turning the exhaust red. The further I drive it the weaker it seems to get. I’m at my wits end. The next thing will be the coil…the plugs and wires look brand new. I suspect the PO had this issue and that’s why he was so eager to swap me it for my 2007 H3 Hummer with a bad transmission. Anyone got any ideas where to go next ??? I’m officially stumped.
