Are you blowing a bunch of smoke? That's a lot of oil to burn.
Id double check for leaks once your rested. That's a hell of a long drive.
Found a dude in Long Island ny that has a 97 2.5l with an auto and ac (won’t be taking the auto) but just the motor has 160k and has new accessories on it like manifold water pump etc that was done 3k miles ago, all for 400 bucks. Ran great before he pulled it out to do an Ls swap. Planning on going down Thursday to pick it up then I’ll just need to find a hoist to swap them. This is the best option I can find besides waiting to save up for a titan rebuilt motor.
WOW great price.
See if you can rent the engine hoist unless you're wanting to buy one. If you are get the 2 ton version from Harbor Freight. The 1.5 ton version has a shorter reach and won't reach on our Jeeps.
I’d prefer to rent. Good to know on the size bc I would have got the 1 ton lol. Are their any stores that rent a hoist like how advance and auto zone that rent tools?
What happens is that the hydraulic cylinder will hit the crossmember/bumper but depending on what type of engine sling you're using you can push the engine back into position.
As you start to pull the engine double & triple check that you've got everything disconnected. I always seem to miss one wire or ground strap it seems.
If anyone knows the fitting there in the portioning valve that broke ( this is a non abs ) that would be amazing but I’ll look to see if it can find it otherwise.
Had more time away from the Jeep but came back to it today and finished it all up. So many little things but did oil, motor mounts, intake, radiator, coolant, bleed brakes, pumped tires back up to 25psi (dropped them to 3psi to get the jeep lower for the little hoist), and had to take my exhaust off and swap my old mid pipe back on bc the one with his motor was messed with and I didn’t see that.
Before I left I did everything else like the tcase,shafts, skid, all belt drive stuff and the belt, starter, grill, bumper, and anything else I’m forgetting. Just so many little things which wasn’t bad since I’ve replaced everything I’ve touched atleast once before so I knew how it all went together. Just a lot of systems to keep track of.
Jeep cranked right over and sounds great. Throttle is a little sticky so ima try cleaning it out but very surprised on how everything has worked out. No codes thrown and all gauges were showing everything perfectly.
