New Jeep, Help Identify What I Have
The tires look brand new but has 0813 on them. If I’m reading that right, it places the tires at almost 11 years? They are wrangler SRA 255/75/17 so roughly 32s.
Didn't see anyone mention this one... I definitely would not drive on tires that old
Don’t be intimidated we have a good illustrations guys can post and we can help you figure this out I’m just doing this on the fly as I’m working.
Have faith. It can be fixed.
Thank you! Yes I'm definitely open to learning more and appreciate all the help this community has given!
Yup, one of the main things I'm going to replace as soon as I can
Wanted to check to see if control arms are possible for death wobble?
See post #15 in this thread. The trackbar is the most likely culprit, especially one with an heim joint. Is this preventative, or are you actually having death wobble? Or are you having tire shimmy?
Reactions: LONGJP2
I am still having death wobble but haven’t gotten around to replacing anything just yet due to time constraints. I'm also really hoping to replace cheaper components before jumping directly to replacing the trackbar
I have driven and wheeled on tires that old.
As long as they aren't dry rotted or cracked they will be fine.
To each their own.
Safe or not (it really isn't), tires that old are hard as a rock anyways.
I accidentally bought a set of tires around that age if you'd like to buy them...
Reactions: John Cooper
What did you buy?
The Mickey Thompson MTZ’s I had were not hard a a rock.
If I remember correctly they were around 10 years old, road fine, balanced fine and worked just as good as new tires.
Reactions: TheBoogieman
What did you buy?
Some BFG AT tire, I don't remember the exact model. Sat in a garage, great tread, no dry rot, absolutely junk
To me a BFG tire is junk anyway. Michelin owns them and they are over priced for what you get.
I am afraid Cooper's will go the same way now that they have been bought out too, but since it's Goodyear maybe that won't happen.
Reactions: annihil8ted
Got around to replacing the front shocks and discovered the driver side was actually seized pretty badly to the point it exploded when I pulled them loose. Possible cause of DW?
Going to continue with replacing the rear tomorrow along with reposition and putting in a new steering stabilizer. Also going to take some time and regrease all the joints.
While under the vehicle, I noticed that the front drive shaft seems to have some rotational play. Is there a way or need to eliminate that?
Bear with me as I'm trying to learn, why does passenger side upper front and toeing out help diagnose death wobble?
While you may or may not need new control arms (easier than changing the bushings), that won't address the upper fronts.
Those bushings are on the axle and would need replaced individually.
No. Again, it is most likely the track bar. Have you done the dry steer test yet as was recommended on the previous page?
This was indeed the worn out part that allowed Death wobble on our '05, front driver's side was so bad you could compress and extend it by hand... no other parts in the steering/suspension were loose at all. (and yes... true death wobble, seats have the stains to prove it) (jk about the stains...)
I have but I didn’t detect any real movement. It all seemed to be lined up properly? I can try again and see if I feel anything. It should be obvious right?
Just finished replacing all the shocks and while I haven’t driven it yet, shaking the car feels a lot better than before
Also got around to regreasing the joints with a locking zert grease gun and was able to put more grease in. Still seeing leaks around the face of the same side as the fittings; not sure how to fix this or if it needs fixing
I did see cracking around the upper control arm bushings, particularly the one on the passenger side. Should I address this seeing that I haven’t felt much in terms of the steering test
As Andy said, set the alignment to toe out 5/8” and see if your DW goes away.
