Hello ,
I am new to the site even though I look at the discussions quite often.
I need help on what to do with my 1999 Jeep Wrangler Sahara 6 cyl.
I have had the jeep 8 years with only a radiator and thermostat replacement when I first bought it.
I have not had any problems with the jeep what so ever except for my airbag light came on and just never fixed it.
I was driving to work with the a/c on( I did notice it wasn't as cold as it usually gets) and the check gauges light came on and I immediately pulled over for all my coolant to spill on the ground. I let it cool off and put coolant back in it to drive it home 45 mins without a/c on and it did fine.
I noticed it had a leak in the radiator and so ordered all parts to replace coolant system.
I didn't know to buy all mopar parts so this is what I replaced.
Motorad 195 Thermostat with weep hole
DAYCO wATER PUMP
Thermostat housing
liland Global oe quality all aluminum radiator.
After replacing all of this and adding new coolant, It did the exact same thing. Overheated and coolant spilled everywhere just like before( only when a/c is on).
I did not burp the system and I did not flush the system as it looked very clean( but maybe hind sight I should have)
Oil is clean, no coolant there.
Can someone help redirect me before I loose my mind.
DAYCO wATER PUMP
Thermostat housing
