You don't run with your windshield down when on the trail?
Up here the trails will dry up around late July early August depending on the previous winter. Once they dry up the dust can be terrible since a lot is volcanic ash and lava crushed up. The windshield can become so covered you can't see out. So we drop our windshield and wear goggles.
There's just something about driving with the windshield down.
ARB Hose Coupling Us Std Npt 1Pk (740112)
I like this ARB connector, even if it is a few more dollars than a standard coupler, because it should be easier to use with that rubber coating.
If I added couplers elsewhere, I'd likely just so standard route.
Do the ARB coupling use a standard air hose fittings like this?
If they do I like the compactness of it.
That's what I'm tracking it accepts.
Agreed - it's a nice compact coupler but I really like the grip on it to make for easier on/off connection.
I'm only planning to use it for tire inflation. I can't use a lot of the hoses & tools from my garage as I went with Milton connectors/couplers that have a larger port for higher airflow. So I'll need to be sure I don't grab my garage hoses to take on the trail.
https://www.amazon.com/gp/product/B001O2ZID2/?tag=wranglerorg-20
OK, I'll wait until you get it and see how you like it. But if you give it a thumbs up I might get 2 for my rig.
Tested out the OBA tire inflation tools I received.
Put teflon tape on the 'standard' connector going to the tire closed (doesn't blow air without connection to the tire valve) quick connect.
Tested it with my air compressor's Milton (high flow) connector and the test went great. Performs as expected.
The nice thing about the Milton high flow couplers is they still accept standard-flow connectors.
Tried to run the tire connector with the accordion hose and that was a disaster...
The plastic wrap is welded to the hose... So this is going back to Amazon and I'll buy another one from a different vendor (likely all the same chinese crap but hopefully the next one doesn't have this issue...)
ARB coupler still 'on order' so hasn't shipped yet even though it has a 25-29 Sept delivery date... Will test it out when it gets here.
I recently picked up a locknflate for my M18 compressor and it works really well if your quick connector lets you down. I’ll probably switch all my stuff to the locknflates.
