I just hit 97k. Dunno what life was like before me.
I would do it. It’s cheap and easy maintenance.
What U joints should I use for a 2004 tj Sahara on a stock Dana 30?
Thanks, I saw it but I also saw that it changes from year to year, just wanted to be sure!As mentioned in the first post, you should use the Spicer 5-760x u-joints.
The advice I've received is that if you can fund the swap, do it. U-joints are cheap. Peace of mind is priceless.I have 2003 TJ non-Rubicon I currently have 103350 miles on it should I change out the Drive Shaft U Joint and the U Joint on the axles? I checked the drive shaft the rear has very to non play on it and the front has no play, I only did a visual check on the axles see nothing wrong with them I got the Jeep with 84,000 miles on it, don't know if the previous owner had changed them out. So big question should I change them all out?
Thank you. I'm planning on doing it soon, I been looking around for U Joint it's so many lol. Any recommendation? I live in the desert don't see too much rain also the ones I seen are grease able.The advice I've received is that if you can fund the swap, do it. U-joints are cheap. Peace of mind is priceless.
There are actually 8 u-joints.The 8th one looks like this-
https://www.summitracing.com/parts/...laming-river&gclid=CMyCxK6J8c8CFUxsfgodx9cMEQ
I have found them much cheaper on rock auto. Amazon is getting real bad on prices.When I click on that original link from Jerry that is shown as a Spicer 5-1310x, it takes me to Amazon but to the 5-1350x listing. Pretty sure that link somehow changed over time and is now the wrong reference (since he listed 5-1310x and the chart above from Denny's shows 5-1310x), and to make it worse the Amazon fitment guide says the 5-1350x fits and the 5-1310x does not.
Just wanted to clarify that for myself and anyone else looking - it's the 5-1310x we're looking for, correct?
I’ll have to check that. I think it’s the original one.There is also a CV centering yoke in there too. If you want to replace it too you need to check if l you have a greasable one or not.
