Webtard help please
mrblaine
Crew Member
Quail Valley, CA
I buy from Sherco. I use these 22-18 g non-insulated butt connectors. I buy them 1000 at a time.
When I went to buy them again, all I can find under non insulated terminals are assortments.
https://www.sherco-auto.com/collections/non-insulated-terminals
They were kind enough to send me a link to the 1000 packs, but I still can't find them any other way. What am I missing?
Let's try again please and this time pretend that you really are dealing with a webtard.
HOME
Click on products which is a drop down menu-
Down near the bottom is- wire connectors and terminals
Click on that
I get this when I do that.
When I click on that, all I get are collections, not individuals.
HOME
Click on that
the links are messed up. move the pointer over any category on this page and look down at the bottom of the screen. they all read yadda, yadda, collections, yadda. in other words the web author doesn't want you to get there from here.
Reactions: psrivats and Zorba
@mrblaine, I see the advantage of these in keeping wire bundles compact. I know that are not one to just buy random stuff off the shelf. I am sure you have settled on a particular shrink tubing that provides the right amount of insulation, is adhesive-lined, etc. Do you mind sharing?
Oddly, the stuff that works very well and especially for the price is the 3-1 and 4-1 Wirefy stuff on Amazon. The better results are achieved when you match the diameter of the shrink tube to the diameter of the wire connection as closely as you can. Not to the thou but the tube doesn't get less material when it shrinks, the material is the same no matter what you can shrink it down to which means the smaller it goes, the wall thickness increases which adds bulk.
Wirefy is a good balance of cost, wall thickness, and quality. I'd like to find some single wall adhesive lined but have yet to do so.
The links are pretty messed up. I am decent with finding stuff online but that website that Blaine posted is just silly. Yes you can eventually find it and NO, that's not how to do a webpage/search.
