Hey guys, I have question between two setrab transmission cooler. Could the dual pass be used so that both in and out ports would be located on the driver's side instead of running one line along the bottom of the fan shroud, like when using the 53-10748 cooler?
TIA for input.
That is not how the 53-10748 is configured. What you see is what you get.
I don't know what the Dual Pass is, but a picture would show where the ports are.
This is the dual pass. It puts both ports on the same side. I was trying to see if anyone has run this instead of having to route the transmission line all the way to the right side. I thought it might be easier with both on the left side or maybe it makes it harder as one line would be pretty short?
The right side is the easier of the two sides to get the lines out of grill and down to below the fan shroud. The left side on a LHD rig has the steering gear in the way so it makes it much harder to get both lines out of that side. But, using the dual pass with the lines on the right side would or should be pretty easy.This is the dual pass. It puts both ports on the same side. I was trying to see if anyone has run this instead of having to route the transmission line all the way to the right side. I thought it might be easier with both on the left side or maybe it makes it harder as one line would be pretty short?
The argument for in/out on the opposing corners is to make the fluid spend as much time inside the exchanger and cover as much area within the exchanger as possible to exchange as much heat as possible. If you agree with this argument, then you figure out how to build it that way.
I would be interested to hear how well the dual pass works.
What makes that cooler so freaking expensive? The Hayden I have lowered my temps by like 40-60F, and I know others here have high praise for the Derale. What makes this thing so special?
Not for nothing but it would be way less annoying if we didn't have to pull the grill to install it.It’s race car parts. Way over kill for a lot of people, but it fits nicely behind the grill, leaves room for Power steering cooler, and it’s really high quality.
The high praise for the Derale is coming from one source multiplied through groupies.
It cuts on and off. It’s loud and annoying. And without a temperature gauge nobody knows what it’s really doing.
I have used and installed several of the under tub Derale fan driven trans coolers. I am not a fan of the noise, the wiring, or the extra length in the cooling lines to and from. They do work reasonably well, not as well as the Setrab in the grill on the highway, they do work better crawling slow but there again, you aren't working the trans as hard crawling slow.Yeah, that's very likely a single source validation. I don't really like anything about the underbody install, switched fan, etc. I'm not sure how it got "popular" but then again maybe I do. But I guess this thread is about something totally different anyway.
with no temp gauge to tell anyone how well it was or was not working
I purposely put the cooler in last, after the rebuild, just so I could know the before/after. On the other hand, XJ Buddy was keen to point out that I was only worried about the temperature because I had a gauge. I mean, he isn't completely wrong; before I had the gauge I didn't ever worry about the temp. I guess ignorance is bliss. That said, if I had to pick one or the other, I guess I'd opt for the cooler and hope it was enough to keep the temps down over choosing the gauge and potentially watching it shoot up thinking "why didn't I opt for the cooler?"
