Haven't tried jumping...Hmmm... can you hear it if you load the suspension by jumping up and down on the front or rear bumper?
Great idea! Its actually what I'm doing right now...Got four vids so far, no luck pinpointing it though.Hmm that doesn't sound like the hollow clunk excessive backlash causes. Know anyone with a gopro? Perhaps you can mount it under the jeep to look at different parts while driving.
There must have been a time
when we could have said no.
Huh? You can't even see the axle... Other side of what? I have more videos...One that shows the front axle, one that shows the rear (both driver's side) and one that shows the center of the vehicle, looking forward at the T-case and Rear DSAxle seems to have play in it. Other side will probably tell you more.
I'm referring to the driveshaft going up and down on the axle end. Looks like the pinion angle is increasing then decreasing. So I was assuming the axle was rotating a bit. By other side I meant turning the camera 180° towards the axle.Huh? You can't even see the axle... Other side of what? I have more videos...One that shows the front axle, one that shows the rear (both driver's side) and one that shows the center of the vehicle, looking forward at the T-case and Rear DS
Oh...Yeah, the jeep raises on its suspension when I accelerate and lowers when I decelerate. That is why the DS is moving like that. I have a vid facing the direction you mentioned...the camera is picking up a bunch of background noise though, so its hard to heard the clunk I'm focused on. I can upload it to Youtube...I'm referring to the driveshaft going up and down on the axle end. Looks like the pinion angle is increasing then decreasing. So I was assuming the axle was rotating a bit. By other side I meant turning the camera 180° towards the axle.
So...I haven't figured anything out yet. I did replace my axle seal and bearings. That wasn't it. Started going through the front suspension this evening. I have two control arm bolts that are seized in their bushings, so the rubber is "wound up" from my recent lift. They look pretty well past it at this point, so I ordered two replacements. Note: I really don't think this is it. I don't get any clunking when articulating the suspension, nor jumping up and down on the bumper (neighbors must think I'm nuts). BUT as @Alex01 pointed out and I've also noticed, its definitely co-incidental with the front suspension lifting. So...I'm going to replace them. Here is the rub...those dumb bolts do NOT want to come out. Might have to cut em...I put the fire wrench on them earlier (Mapp gas)...got a little motion out of them. I'll need to borrow some tanks if I need Oxy/Acetylene.
I suppose I should check the tranny mount...but its brand new, so I doubt that is it. This is getting frustrating. I want to drive my jeep!
I got the nuts off... The bolts themselves are seized in the bushings. I have tried heat... No luck yet.I haven't seen you say this but have you heated up the bolt to get the nut off — it has heavy lock tight on it and the heat will help you break the nut free if you can get something like Areo Kroil in there it might help you out.
good luck
