15x8 their either Quadratec or Extreme Terrain, not sure which.
They're Quadratec Rubicon Xtreme wheels. (y) I had the Extreme Terrain Mammoth Boulder wheels.
https://www.quadratec.com/p/quadratec/rubicon-xtreme-wheel-wrangler-yj-tj
In the process of replacing my thermostat and found a broken bolt flange on the housing and what you see in the pic below. Flushed the entire system, including heater core, and everything looked ok aside from a little debris. Appears the previous owner was aware of the broken flange and just kept adding gasket maker until it would stop leaking.
Waiting on a new Mopar housing in the mail to put it back together.
got my drivers side seat cover "True-Shield" on, 3 deg out so didnt get the passenger side done me dang fingers quit working and my nose was as snotty as a 2yr olds
there WILL be NO swamp-ass right now with these seat covers, only shrivel-butt
also noticed the door side of the seat cushion is rotted out and listing towards the door, ill be ordering a new one after the holidays along with those slider buttons
Finished up the rear brake cylinder and drum replacments, bled the brakes - 1st time I've ever done that job. The old brake drum came in handy to keep the fluid collection tank upright.
Took it on a 30 mile round trip to dance class tonite - all seems to be well.
Painted wheel cylinders! Nothing says I do my own maintenance more then this!
Welp... tried to fix my brakes for the 3rd time in 4 days. I got my 2002 wrangler X on Friday. Pulled the E brake at the gas station and since then the E brake light will not shut off and i can feel it slightly catching. But the alarm noise is gonna do me in. I replaced the e brake cables, and all the adjustment components in the rear wheels. Still it persists
Does the E brakes works as it should? could it just be the switch is stuck? I believe that switch is just picking up the handle position.
Yeah, it pulled up about ⅝ of the way up and was tight, vehicle wouldn't move. Tried rocking it while it was pulled to knock it loose and the slow reverse and pull. After replacing the cables the tension is looser than before, still need to adjust the nut to make it tighter but that alarm still won't go away
