I've been relying on my iPhone for gps & navigation and started looking for a solution . I don't want to install a double DIN headunit and the iPhone is a bit too small most times.
I was looking for a solution that would let me use an old, retired non-cellular iPad mini 4, for nav with GaiaGPS, Google/orApple Maps and Garmin Earthmate.
Since a non-cellular iPad doesn't have onboard GPS (cellular equipped units do, and they can be used even if you don't have a cellular subscription activated), I could mount a nearby iPhone and use its GPS via Personal Hot Spot, but it is slow as molasses and stresses two important batteries simultaneously .
I purchased a Garmin Glo2 external GPS receiver and paired it with the iPad and it seemed to work fairly well. Although the battery performance on the Glo2 is questionable.. I think they report 13 hours of tracking but it takes more than that to fully charge if depleted.
Then it dawned on me that I might be able to pair the Garmin InReach Mini I already have (and use primarily for SOS security when solo backpacking) and use it with the iPad. Sure enough, as long as I unpair the Mini from my iPhone (it can only be paired to one device at a time) it paired to the iPad with no problem. Gaia's technical bulletin says the iPad+InReach Mini won't work, but it seems to perform great. The two devices pair in a few seconds, the Mini locks onto satellites faster than the Glo2 and my experience with the Mini over the last few years of backpacking with it is that the battery is an absolute rockstar.
The InReach Mini works with Gaia, CalTopo, Garmin Earthmate, Garmin Explore, Apple & Google maps. Also found that with the Mini clipped to the footmans loop on the windshield surround it was able to secure and hold satellite connection through the soft top fabric. I returned the Glo2, repurposed the old iPad and now have all the mapping apps I use most. The aging pad battery might be the weak link.. it draws down faster than it charges. If needed I have a newer iPad Mini 6 that might be at battery management.
